Ok so this is probably very use case specific but here we go.
We have an existing solar inverter and are wanting to trial some Victron gear on a small scale before going all in on a new build.
What I would love to happen is run a Multiplus-II as per the "in-line" diagram on the website.
However I have a question regarding ACout1 and ACout2.
When the grid goes out, batteries kick in and supply ACout1, cool, no problem there.
Do I put the PV inverter on ACout1 or ACout2?
I obviously want all critical loads supplied for as long as possible. But assuming the PV is going great and the batteries are full with load1 taken care of, will it also try to keep some non-critical loads going on ACout2? I don't want ACout2 to drain the battery but if it could use the PV that would be swell.
Any thoughts here?
