gainestr avatar image
gainestr asked
Mopeka Node Red Tank Sensor - Missing Raw Value in node
Is there a way to add the Dbus path: /RawValue to show the tanks remaining volume in cm within the Mopeka Tank Sensor Node? Or, am I just missing a formula to convert the /Remaining(which is in m3 ) into cm? Online conversions don't give me the same reading that I see in the MQTT value and I prefer not to run MQTT if I don't have to.
Node-RED
