Good day
Does anyone know what the rated amps is for the second output on the inverter.
I want to connect the geyser and gas stove to the second output and overide the relay.
All I can find is the rated amps for the 1st output.
Thank you
Good day
Thank you
The auxiliary output is rated for 32A. I assume you have the 230V model.
See the tech specs for 48/5000 on this page.
74 People are following this question.
