I need to do a short term inverter plan. Can I run the Multiplus-II as just a stupid 12V to 110V inverter. No other groovy features, just 12 in and 110 out?
yes you can.
Thank you Rob. I love people who actually answer the question - I tested and by golly it worked. Now step 2 in this process will be to eliminate the existing stand alone crappy 1K inverter transfer switch. So, to my question - If I run my 110 from shore power to the Multiplus -II will the Multiplus transfer switch feature work without any other fancy Victron stuff hooked up to it?
Regards,
Steve
Make sure you have a galvanic isolator on the earth/ground of shore power.
75 People are following this question.
