aioannidis avatar image
aioannidis asked
Gerbo combination
I am an engineer about to install two systems, next to each other. Each one will consist of 1) 3pcs Quattro 15000. 2)1pc lithium battery rack. 3)1pc Gerbo Gx 4) 1pc 30kW 3phase diesel Generator.
If I have only one touch screen,
1)can connect the two Gerbo to each other and control them with one sceen?
Or2) can I connect the touch screen to whatever Gerbo I want to Access each time? I mean plug it and unplug it every time
Alexandra avatar image
Alexandra answered ·
@aioannidis@engaia.gr
You cannot join two cerbos together.
The screen would have to be unplugged and plugged.
Or you can use a tablet with a browser open for each remote console and switch between tabs. (Available if all are connected on the same LAN)
aioannidis avatar image aioannidis commented ·
Thanks for the response
