sean-bezuidenhout avatar image
sean-bezuidenhout asked
Adding different batteries dc to dc auto transfer switch
Howdy there
I have inherited 2 x new 5kva Batteries (Freedom Won eTower LiFePO4 Battery 5kW 52V) which are not the same make as my current two.
I am trying to work a plan to bring this capacity into my setup.
My thinking is this:
Add the 2 new batteries isolated from the existing two batteries with a DC to DC Automatic Fail Over when the first two are discharged it will transfer to the new batteries vica/verca
My Current Setup looks like this:
Victron MultiPlus-II 5000va with
12 x 420w panels connected to a Victron Smartsolar controller MPPT 250 100
2 x Freedom lite won 5/4 Batterys
Any suggestions? Is there a DC to DC ATS switch like this?
power
There's also the question of charging.
Ideally you want a single battery bank.
Have you spoken to the battery maker's to see if they're compatible?
