After disabling DVCC it warns me to reset the VE.Bus. Did not find the procedure to do this.
What is expected here?
Switch off and on with the inverter with the front rocker switch.
You should always shut a three phase down using the software switch on the GX.
So, Off and On in Switch. (found under the device in the device list)
74 People are following this question.
