johnwbeem avatar image
johnwbeem asked
No altitude limitation for Quattro in 120 volts but there is for European 230v
I was looking at the Quattro and noticed there is an altitude limitation for the European version that are 230 V, but not for the North American version at 120V. Is this a mistake, or does the higher voltage of the EU version cause higher temps and greater chance of arching due to thinner atmosphere than the NA 120V version? There seems to be no limitation for the Multiplus for either version. Is this correct?
