gexle avatar image
gexle asked
BUG RpiTemperature package -> Relais Temperature no setting
Hello As you can see I wanted to do a temperature control over the relay but when I click on temperature I just see a gray screen or mask.
Cannot create a temperature rule. Can't adjust the temperature why?
Thanks
gui mods
gexle avatar image
gexle answered ·
The pictures are gone I'll re-upload them today so you can see Kevin.
Thanks
gexle avatar image
gexle answered ·
Hello Kevin
Is it a mistake that nothing is displayed so there is a choice?
Thanks
gexle avatar image
gexle answered ·
Everything I do doesn't work. I just can't create a temperature rule.. Can you please take a look at this Kevin?
Thanks
gexle avatar image
gexle answered ·
Hello
Got the relay board module up and running. Gipos changed and running!
Can I perhaps reverse the switching state somewhere, i.e. instead of opener -> opener for all relays?
Furthermore, I still can't adjust the temperature control.
Could you maybe take a look at why that's the case Kevin please.
At the moment I can only turn everything ON and OFF by HAND!
Do I need a shunt or something or why does everything stay gray?
See picture above!
Thanks
satmaster200 avatar image
satmaster200 answered ·
Same here (Raspberry Pi4 running v3.00~21 with guimod v7.16), just a white screen:
Not sure though, if this is a guimod issue?
I will try later with a stock image...
gexle avatar image
gexle answered ·
@satmaster200
Hello Yes, I thought I was the only one here!
I started from a fresh v2.93 version. In this stock version, there is no "relay" page showing up. So I had to install first Kevin's Setuphelper first and then I also added his package "RpiGpioSetup":
Only then I was able to access the "Relay" page, and could assign "Temperature" to Relay #2. But still, as in my and gexle's post above, the "Temperature control rule" page is just empty, plain white.
I'm going to generate an issue on @Kevin Windrem 's GitHub page.
https://github.com/kwindrem/RpiGpioSetup/issues
At the moment it seems not to be an issue related to GuiMods, because I have not installed it on my "from scratch test system" (as you can see in the screenshot above) and the issue is already there.
Let's see if Kevin can reproduce our issue on his otherwise very fine software and solve it!
gexle avatar image
gexle answered ·
Hello Satmaster200
Clearly understand then it will probably be a Guimods problem.
Yes, it would be nice if Kevin could do something.
If I may make a wish, Kevin. :)
Isn't it possible to apply the temperature selection to each relay?
Thank you very much
Kevin Windrem avatar image
Kevin Windrem answered ·
I was able to reproduce the blank Temp rules page. This occurs if there are no temperature sensors OR if the temperature relay service is not running. This service will crash if the RpiTemperature package from TimD1981 is installed.
Error: ValueError: Invalid object path '/Settings/TempSensorRelay/Rpi-cpu06/Enabled': contains invalid character '-'
It has nothing to do with GuiMods or RpiGpioSetup
Hi Kevin!
You are right! Stupid me, my appologies. As soon as I added my Ruuvi-Tag as a Temperature Sensor, sure enough it all showed up:bildschirmfoto-2023-03-02-um-195720.png
bildschirmfoto-2023-03-02-um-195727.pngAnd thanks for the hint with RpiTemperature package from TimD1981 this package was indeed installed on my other test-installation.
Seems TimD1981 needs to fix his implementation.
Thanks a lot!
gexle avatar image
gexle answered ·
Hello satmaster200
I have Ruuvi how did you do that now?
Where and how did you add Ruuvis?
I have nothing install from TimD1981..
How and where do I add the Ruuvis sensors?
Thanks
Sure, I did like this:
First go to settings, scroll down to "I/O":
bildschirmfoto-2023-03-02-um-204705.pngEnter, and select "Bluetooth sensors":
bildschirmfoto-2023-03-02-um-204712.pngEnable:
bildschirmfoto-2023-03-02-um-204722.pngand wait a few seconds,
till Ruuvi sends a broadcast:bildschirmfoto-2023-03-02-um-204743.pngTurn on the "switch" at Ruuvi:
bildschirmfoto-2023-03-02-um-204749.pngGo all the way back to the "main page", there you should see the data measured from Ruuvi:
select it there (by klicking the right arrow button), shows this screen:
bildschirmfoto-2023-03-02-um-204832.pngUnder Device you can give it any name you like, "Karl-Heinz" or I just called it "Ruuvi" :-)
From here on, you just go to "Relay" -> assign Relay #2 the "temperature" function, click on "Temperature control rules" and should see the screenshots I posted above.
gexle avatar image
gexle answered ·
Hello Kevin and Satmaster200
Have RPIT temperature Package from Timd1981 installed ..
I didn't have on the screen yesterday ..
Then I will have to wait until Timd1981 solves the problem so that I can then also make a temperature setting.
At the moment this is only possible for relay 2 you can change it in the script that you can use it for everyone?
I'm not a programming so I ask!
Thank you
Allowing temperature, generator start/stop and tank pump is something I've looked into but it is a lot of work. Won't happen any time soon.
gexle avatar image
gexle answered ·
Hello
Yes I think so.
I said it would be great if you could also apply it to the rest of the relays, so separately from each other, I'd say!
Thanks for your work
gexle avatar image
gexle answered ·
@satmaster200
So at the moment you can only control relay 2 by temperature, right?
Kevin Windrem avatar image Kevin Windrem commented ·
True
gexle avatar image
gexle answered ·
Thank you wanted to say again, so far everything runs flawlessly...
Thanks
