5kva multi-plus inverter not charging after heavy rain falls with thunder lighting. not even seeing the mains from VE-configure when i check, what can i do to fix this problem
Sounds like you will need to take the unit to a service center for check and repair
I presume that you have checked to make sure there is AC power on the Inverters AC1 in Connection
8 People are following this question.
