Hello everyone, Can anyone explain me why AC input Current fluctuate so much? See the picture attached.
I have a system with Multiplus 48/5000/70, 4k solar panels, 200Ah battery in ESS assistant mode. Grid offset is 30w.
Thanks
Thanks
Hi Vali,
The system is installed in Romania? What grid code and LOM type did you set?
BR,
Mihai
Hello MihaiR,
Yes, the system is installed in Romania.
I set grid code " other: not compliant to any grid code standard" and LOM " Type B".
Do you have some suggestions about that?
Thanks,
Vali
No any suggestion? Victron technicians, please advise me if is something wrong.
Thanks
8 People are following this question.
