Off grid: If I had two Multiplus II 48/8000 (not in parallel since they cannot operate in parallel) that were connected to the same battery bank, with only one Multiplus II connected to a generator for charging the battery bank, but that supplied two separate AC outputs to two separate load panels through two separate sets of cables, would the Cerbo GX have any issues with this? Would the Victron Remote graphic show two inverters pulling power from, and one inverter sometimes charging, the same battery bank?
Most importantly, could I set it somehow so that the sum current draw from the batteries by the two inverters would not exceed a certain current?
My batteries can supply 800A. But the cables are limited to only drawing 400A. I would want one inverter to be able to pull 300A while the other inverter drew 100A. As such, I want to avoid limiting both inverters to drawing 200A each. Can the Cerbo GX orchestrate this sum total limit of current draw from two inverters that are not operating in parallel?
