My Quattro is reading the incoming power incorrectly
If that is a generator, it is not running well or something is happening on one phase there.
(Weird frequency if it is grid.)
It is likely the power is being rejected as it falls out of parameters.
Did you use a good DMM to verify the incoming voltage and verify the correctness?
A new inverter is on its way and I will seel if that works :-(
32 People are following this question.
