brad-australia avatar image
brad-australia asked
BMV600 Shunt compatiablity?
I have a BMV600 the shunt has failed, can I instal a SHU500050100 500a shunt? Or any other new shunt. Or do i have to repalce the wholes BMV monitor and Shunt?
Thanks
BMV Battery Monitor
wkirby avatar image
wkirby answered ·
What exactly has failed? Is it the actual shunt or is it the PCB.
SHU500050100 is for the actual shunt only - without the PCB.
https://victronenergy.co.nz/products/shunt-500a-50mv-45-x-28-x-120
If it is the PCB that has failed, then you can just get that part separately.
https://victronenergy.co.nz/products/pcb-for-shunt-bmv-600s-700
