What is the AC output wire size MultiPlus 12|2000|80, and it's 120v
I've been searching this for a while, but only found some answers for 12|3000.
Thanks very much.
Thanks very much.
You will be more than safe using the recommended wire for the 12/3000 120v
well, per the victron manual for the 12|2000|120, (you didnt specify wether you had 230 or 120, if you have the 230 version youll need to check your manual for that info, since PowerAssist will likely be different)
AC-out
With its PowerAssist feature the Multi can add up to 2kVA (that is 2000 / 120 = 17A) to
the output during periods of peak power requirement. Together with a maximum input
current of 50A this means that the output can supply up to 50 + 17 = 67A.
So your inverter can output up to 67A, Further, you need to know how long the cable is going to be, once you get this information, you can plug that into a wire sizing calculator (make sure its for AC Power, there are several online) and get your answer!
75 People are following this question.
