castijn avatar image
castijn asked
Why is multiplus not feeding when demand is there?
I just finish installation of multiplus 2, ET 340 and Cerbo.
It must be a wrong setting somewhere (no idea where) but when my home consumption is e.g. 1200W I expect that the Multiplus (with full batteries) will pop in and deliver the power. I only can make the multiplus work to put in a negative value e.g. -900 W ( ESS setting should be +50) , which will constantly provide 900w. Modus, optimized without battery life). As for info : I use 1 Multiplus with ET 340 (combined grid values).
Suggestions are very welcome!
Thanks!
Peter
Multiplus-II
@Castijn
Are you trying to feed in to the grid or feed your loads?
How have you programmed your inverter?
castijn answered ·
I Try to feed my load.
Inverter has been programmed according to the specs. I am afraid that I have to check these, because the Cerbo is (to my opinion) programmed OK
