for the digital input GPIO ports, how can I (permanently) set the internal pull-up resistors activated?
for the console I found this:
gpio -g mode 4 up # up
But how to activate permanently?
You could set the state of the pins in config.txt
See also: https://www.raspberrypi.com/documentation/computers/config_txt.html#gpio-control
I do this with a DT overlay in my RpiGpioSetup package but the config.txt method is cleaner if it works for Venus OS. I haven't tested it yet.
Raspberry Pi running Victron’s Venus firmware - Blog Post
Venus OS Large image: Signal K and Node-RED - Install
raspberrypi install venus image
62 People are following this question.
