olegv avatar image
olegv asked
MultiPlus2: 3phase vs. Single phase 3 AC inputs
Hi all
There are many topics re 1ph generator & 3ph system, but can't find concrete answer :(
See bitmaps please, now it works as 3ph system, no problem:
What (bad) happens if switch it to "Single phase/3 AC inputs" (in ideal case without re-wiring)
The main idea/problem - how to connect 11kVA 1ph generator to 3 MultiPlusII 5000. If connect it to L1 with "switch as group is OFF", it will use only, say, 5kWt from generator for L1 and charger, but I need more, say, 2.5kWt per phase. No "real" 3ph devices.
1677163430846.pngThank you
Generator
olegv avatar image
olegv answered ·
Nobody wants to help :)
olegv avatar image
olegv answered ·
Self-answering style :)
Tried - doesn't work, can't understand what "3 AC Inputs" means here and how it should work if any.
L1 - OK, started accordingly, but L2-L3 - "overload" alarm, AC Output was not connected to the chain.
