Hi all, I have recharged my off-grid system after the batteries ran right down and the system shutdown. It's showing charged now but the blue and yellow lights are flashing. Any thoughts? Thanks in advance.
Thanks, danmc, but don't know how to do that... first time I've had any problems with the system so I'm a bit in the dark (though not now literally, thankfully)...
You can clear them via your Cerbo GX (If you have one) or By connecting to the charge controller itself on a mobile device via bluetooth with Victron Connect (If it's a Smart Solar). If it's a Blue Solar with no bluetooth you'll need a VE Direct cable and Victron Connect running on your Laptop/Macbook. If you have a Cerbo GX you may also be able to clear it via VRM.
78 People are following this question.
