Good evening,
since my own GenSet (Hatz Diesel 1,9kW) is still in repair, I just use this Winter the 6th time a rental SDMO HX6000. But this is now the second time, where I have massive issues with my MultiPlus-II 24/5000.
When I started the Generator this morning around 9:30, everything went OK. Once the Tank was empty afte 2 1/2 hours, I connected a 20l Kanister to it (always Bensin 98) and it was running 8 hours perfectly. The SOC reached 85% and the Battery was at 28,1V.
Now I had to get another 20l Kanister and restarted the Generator and hoped it can thenext 8 hours until 04:00 in the Morning and the Battery is 100%.
Not even 20min later the generator got a hikup and the MultiPlus-II went from bulk charging into Inverter Mode.
Interesting is, that in Inverter Mode the MultiPlus-II show in the ColorControl GX 14W power consumption. WTF?
There is NOTHING connected!
The the MultiPlus-II switched back into Charging mode and now the power consumption on AC1out is 146W!
The Inverter get again a hikup and the MultiPlus-II switch back into Inverting Mode.
@VictronStaff : Can it be that the MultiPlus-II is defective?
I have usually set the AC1in current to 17A which the HX6000 is rated for 20,9A and currently I have reduced the Input current to 11A and for now it works, but the charging is only with 65A and the Battery Voltage is down at 27,1V.
Note: I got the MultiPlus-II in October and after setting the input current limit to 17A plus the battery absorbtion Voltage to 29,6V I have nothing else touched and it was working the first 4 times perfect, but now this 2 times everything is messed up.
Thanks for your Help
