andre-de-lange avatar image
andre-de-lange asked
Connecting 4 charge controllers
Hi , we have connected multiple charge controllers MPPT 250/100 to gerbo 3x ve direct cables at multiple installations. Runs like a dream.
We need to connect 4 x 250/100 mppt via ve can.
Can we please have the gerbo settings and wiring diagram to connect to gerbo GX. We have all cables and terminators.
Regards
André
MPPT Controllers
nickdb avatar image
nickdb answered ·
Uhm, CAN devices are daisy chained with a terminator on either end of the chain. This should already be documented in the cerbo manual, not that it is complicated.
Sections 2.4.3 and 2.4.4
andre-de-lange answered ·
Tnx we have done that. What is the gerbo setting on for this installation ?
Andre
If you have used the ve.can port, it should just work. Ve.can will already be at the right baud rate.screenshot-2023-02-19-at-154515.png
Just check no one has fiddled with the port settings.
And try some other RJ45 cables.
Tnx again.
What is the correct ve can baud rate setting on the gerbo gx ?
André
VE.Can is 250kb BMS.Can is 500kb
