The manual lists 1.6Nm but that isn't for the M6 bolts that the 48/8000 uses is it?
Hi
For steel M6 8.8bolt is 11Nm
For steel M6 4.5bolt is 3.7Nm
Most bolts used on electrcal terminations is 8.8 grade
Not sure what grade Victron uses?
Regards
Rob Duthie
NZ
72 People are following this question.
