Working oft Solar for 2 months without issue, inverter side still fine
plugged in to shore power yesterday and switched to charge only, worked initially, then 2nd time changing over to charge only green light flashed 4 times, now no lights at all and no volts where ac cable enters box
manual mentions AC input fuse or breaker, is this within the unit??
