johanz avatar image
johanz asked
Inverter selection
Can the Victron community give me some advise on my intended upgrade, I have RV that is now 7 year old and I have just changed from Lead Crystal batteries the Lithium Ion, my existing equipment is a follows:
4 by 300 amp solar panels
MorningStar TS MPPT-45 controller
3 x (newly added) PylonTech UP 2500 24V 2,84Kwh ea
Dometic Combi 2000 inverter charger (need to change this to Victron)
I now need to change my inverter to accommodate the Li-Ion charging and I was looking at the MultiPlus 11 or the GX, what would you advise? And what would be the best remote control, & is the GX worth the extra cost when in a RV once setup I would only require the remote to switch on and off & see the usage etc.
Appreciate any advise & comments
Thanks Johan
Michelle Konzack avatar image
Michelle Konzack answered ·
The GX allow you to setup the MultiPlus-II without a computer, while the NON-GX would need the VE.Bus to USB-Cable or the MK3-USB Cable to setup.
johanz avatar image johanz commented ·
Thank you
nickdb avatar image
nickdb answered ·
The GX provides the comms for the battery's BMS (CAN connection), which is recommended so the battery can manage the inverter. This won't help a third party MPPT but would if you replaced it with a Victron, It provides a lot more control.
There is little difference in cost between an integrated GX vs a standalone Cerbo, the latter which has better connectivity, relay control, sensor inputs etc.
For mobile use I would still keep a mk3 cable handy.
Thanks
