pioneer01 avatar image
pioneer01 asked
MPPT 100/20 Load switch low voltage level
I configured MPPT load output with low voltage level 22,0 V and high voltage 25,0 V as you can see in the screenshot.
Basically everything works really fine but I don't know why load output is disconnected at ~22,3 V every day:
Does anybody have an explanation for that? Jumper is removed and Raspberry Pi with Venus OS connected on VE.Direct Port.
Thanks for your support!
MPPT Controllers
@pioneer01
Maybe just a reading difference. Have you tried adjusting your cut off voltage 0.3v lower?
pioneer01 avatar image pioneer01 Alexandra ♦ commented ·
Hi Alexandra, I can eliminate reading difference because I observe the cut off at 22,3V live too. Didn't adjust the voltage lower. Thought someone can explain the behavior.
pioneer01 answered ·
It seems that there is an offset of about 0,3V. I configured cut off voltage with 21,7 V now. MPPT disables load at 22,0 V now.
Can somebody explain this behavior?
