thub avatar image
thub asked
How do I install BMV-702 with two 12v batteries in parallel?
I am confused by the Installation Guide for my new BMV-702 to be setup with an auxiliary battery. The Guide shows both battery positive terminals connected “to load”. I only have a single wire supplying power to my travel trailer. Don’t I need a battery cable connecting the two 12v battery positive terminals in order to get the capacity benefit of having the two batteries in parallel? I prefer to connect the load wire to the auxiliary battery – but does it matter?
BMV Battery Monitorinstallation
Paul B avatar image
Paul B answered ·
if in parralle then the negative leads from BOTH batteries go the the battery side of the shunt
marco-russian avatar image marco-russian commented ·
So instead of connecting the negatives on each battery to each other both go to the Shunt? do you have a diagram to explain this?
Matthias Lange - DE avatar image Matthias Lange - DE ♦ marco-russian commented ·
https://www.victronenergy.com/upload/documents/Wiring-Unlimited-EN.pdf
wrong:
right:
The yellow point is where the Shunt should be.
We mostly use the "diagonally" wiring.
Victron BMV battery monitors product page
