And if so, what's the best way to discharge the capacitor? I used a light bulb to charge it up from a 48V battery bank.
A light bulb should work.
The caps can cause a nasty discharge spark if the DC connections are shorted but other than that I don't see an advantage to discharging them before transit. The caps will eventually discharge once the battery connection is removed but might take minutes.
Same for precharge before connecting the battery again.
When off they discharge quite quickly. Once disconnected turn the power switch on and off a few times. Shouldn’t need to do anything else.
73 People are following this question.
