Is there a way I can connect both a BMV-712 and a MultiPlus 2000 to NMEA to view from my MFD but without buying a CX device?
Won't work without a GX device - but if you use a Cerbo GX you'll also be able to use the Ethernet connection giving you a lot more monitoring and control options (if supported by your MFD): https://www.victronenergy.com/panel-systems-remote-monitoring/marine-mfd-gx-integration-raymarine?_ga=2.37262048.1119109240.1675939401-1939561816.1675109670
34 People are following this question.
