pe3030 avatar image
pe3030 asked
modular fuse holder for mega-fuse
I have noticed the bolts are exposed on the bottom of the fuse holder, which I found very odd and have not seen before on any fuse holder on the market. There seems to be a shock/short hazard when mounting these fuse holders as there is not even a half millimeter between bolt and mounting surface. What do you recommend for mounting these fuse holders?
fuses
Paul B avatar image
Paul B answered ·
usually the fuse holder are mounted on NON metallic products, as the units are rated for less than 50 volts there is no shock hazzard, and to avoid a posiable short hazzard please mount on a non metallic surface would be my recommendation
Fuses & fuse holders Product Page.
