1.
The cable entry is not big enough to feed the cable into the multiplus2.
Any ideas on how to fix this in a safe and acceptable manner?
2.
Is it safe to insert the finestranded boat cable into the spring loaded terminal?
1.
2.
To insert fine stranded wire first give a little twist to the bare wire and ensure that there are no stray strands. Insert a small screwdriver into the connector release socket to open the spring loaded connector, insert the wire, then remove the screwdriver.
Have a look at this thread on the same subject:
https://community.victronenergy.com/questions/171883/ac-cable-sizing-for-multiplus-ii-485000230.html
Thank you,
But look at those answers.
VICTRON, help us out please.
Are these units even suitable for installation onboard boats/yachts?
Are you having trouble feeding the cable through the grommet?
The manual mentions to use a ferrule.
Dont forget the galvanic isolation.
37 People are following this question.
