I want to use a Multiplus II 48/3000 GX together with a Pylontech Battery as a UPS in South Africa. The Pylontech battery will be connected to the Multiplus via CAN.
South Africa currently has a huge problem with the power stations. Therefore they have load shedding in place and the power is turned off 2-3 times a day for 2h.
My question is how to configure the Multiplus II. For now we won't be using solar panels, however that will be an option for the future. The essential loads will be connected to AC out 1.
For now the Multiplus II will be used just as an UPS for the essential loads.
I have a couple questions regarding this setup:
1. Which grid code should be used? "South Africa" or "None" as I obviously don't want any backfeed to the grid from the battery.
2. Should the ESS assistant be installed? I don't think it's really needed as I do not want to store energy. Or are there advantages when ESS is installed?
Thanks in advance for any suggestions.
Marcus
