brianlee avatar image
brianlee asked
Cannot find Muti
Has anyone ever come across this before?(see attached picture)
I have two Multiplus 2 48/5000 in parallel and when trying to setup a ve.bus system in quick configure or system configurator I get this error message.
Both Multi's have the same firmware version.
VE.Bus
Paul B avatar image
Paul B answered ·
check the quality of the cables you are using for the ve bus
brianlee answered ·
Tried multiple new cables, do you know if you can roll back to factory set Firmware?
@Brianlee
Use victron connect for setting it up into parallel.
That way you can also check if the firmware update was good as well.
