btaylor avatar image
btaylor asked
MTTP charging issue
My MPPT solar charger seems a little erratic. In the above screen shot it was bulk charging 3 days ago but no float charge. Two days ago the solar panel voltage was higher but there was no charge. If somebody could tell me what the problem is I will be most grateful. Screen shot of the settings below.
MPPT Controllers
ingo21 avatar image ingo21 commented ·
according to your solar panel pmax and yield it seems not to charge at all or very very little
check your solarpanel and the connections to it
Alexandra avatar image
Alexandra answered ·
@Btaylor
You pv voltage is barely or not really 5v above battery voltage the mppt will not start up to charge.
But as @Ingo21 mentioned also check for reverse polarity.
What is the VOC of your panel/s?
