wessel-du-plooy avatar image
wessel-du-plooy asked
MPPT Does not charge. Shows PV voltage = BATT voltage
My MPPT controller shows 0W yield from PV charging. When I measure the 140W panel directly, I get 18-24V from the panel. As soon as I connect it to the MPPT controller, I measure ~12V on the cables while connected. I am confused :)
I do not recall any changes to the system made. I might have once reset all my Victron devices (SmartShunt + MPPT) so it could be related to some setting.
Any advice greatly appreciated.
MPPT Controllers
Similar problem solved with a multimeter.
Be safe and if this helps, or not let us know.
