david-ohara avatar image
david-ohara asked
Green LED (Inverter ON) to Orange LED (Charger Float)
I have a “Blue Power MultiPlus 48/5000/70 - Blue Solar Charge Controller – MPPT 150/35 - BMV 700 Battery Monitor. My system worked without ANY problems from, 24 Nov’18, until, 5 Apr’19 (131 days), throughout one of the worst winters in Crete, Greece. Since the arrival of beautiful sunny weather, a problem started. Green LED (Inverter ON) to Orange LED (Charger Float), since 5 Apr’19 until now 16 May’19 it has happened 8 times. Sometimes if I switch the Inverter OFF-ON it comes back on. Sometimes this solution takes Hours/Days. P.S. I have NEVER connected my generator Lowest Voltage = Zero, Highest Voltage = 58.2V I have 4 x 200Ah batteries ....
sorry it is taking me some time to navigate around
float
david-ohara avatar image david-ohara commented ·
Sorry for not being so clear about this .... My Inverter goes OFF at random times ....
When ON I see - Green LED = Inverter ON = situation normal >>> Then goes OFF ...
I see Orange LED at Charger Side FLOAT ... sometimes I can switch it ON almost immediately ... other times it takes hours/days .... recently I connected my Generator to Inverter... which should enable me to start up GENI when NO power ... OK with me ? ... When my Invertor went OFF as above I started the Geni ... Power was restored for all of 20-30 seconds ... then OFF again ... this time Orange LED at Charger side (Absorption) ...
As I said before ALL winter my PV system worked ( a very bad winter in Greece) and I had nothing else connected - No Geni - Nothing ... when the good sunshine arrived it keeps closing down
Kristof G. avatar image
Kristof G. answered ·
So if i read this right...
Leftside of the inverter is orange led on AND
Rightside is the green led inverter on?
So that means that the battery is in float-stage ( battery is full)
Edit: if you have a phone, you can download the victron app "victron toolkit"..
And search for the led status in the app ;-)
Sorry NO ... Green LED (Inverter ON) >>> to OFF <<< (Orange LED (Charger Float)
