stevie-b666 avatar image
stevie-b666 asked
MPPT 250/100-MC4 VE.Can - Blocking diodes?
Hi...
...as the controller has only a single tracker, I understand the three MC4 pairs are connected as one pair internally.
Are there any built-in blocking diodes within the controller for the parallel connection, or is the expectation that each remote PV array feed is fitted with a bocking diode to prevent backflow?
Just want to avoid doubling up on blocking diodes...
KR
Steve B
MPPT Controllers
JohnC avatar image
JohnC answered ·
Hi @Stevie_B666
The 3 MC4 pairs only exist because they're rated 30A. No internal string diodes, they just join to a bus. Add your own.
stevie-b666 avatar image stevie-b666 commented ·
Hi @JohnC
... thought as much.
I'll do victron's design work for them and extend the Charge Controllers mc4 with a set of inline MC4 blocking diodes and thus improve the system's fault tolerance.
KR
Steve B
Kevin Windrem avatar image Kevin Windrem stevie-b666 commented ·
Many panels, especially those that have paralleled strings, have blocking diodes built in. If they do, the additional diodes will introduce a slight loss you could avoid. It also increases the startup voltage slightly.
