Hi I've recently installed a victron 12/3000/120 inverter charger in my van, The problem, I left the van on shore power outside my house plugged in to top up the Lithium batteries (2 x 280Ah packs) prior to going away. Unfortunately the next morning (very cold) everything was dead, nothing on the bmv display and batteries showing no readings via multimeter.
After it warmed up the display and batteries showed a voltage of 13.8V (float) as set on the batteries' BMS. However when i went to plug in the shore power on the campsite the 'mains on' led on charger side of display along with bulk, absorption & float are all off.
When the unit is switched on only the inverter led lights up. I have replaced the fuse on the lynx distributor and left it off after that did nothing. Have read forums and turned done the charge current to 30A from 120A that did nothing. I currently have the input supply to the unit set at 16A.
I have a week before the window closes (30th Jan) to return it to the supplier.
Any ideas what could be causing the problem?
Many thanks in advance
Roger
