Hi. With a Multiplus II I understand that I can have essential loads on AC-1 out and non-essential on AC-2 out. And to make this useful the DB board needs to be split - no problem so far. But what if I have essential and non-essential loads on the same plug circuit in the house? eg I have internet, a printer etc on a plug circuit, but on the same circuit we sometimes switch on an air conditioner, or maybe plug in an iron to iron clothes. It could also be a heater.
So when on batteries I guess this would overload the system which would then trip. That is expected and people would need to have discipline. But what happens when mains comes back? Does the inverter still trip on overload according to its power spec? Or does it switch the power through and no longer monitor the overload (because it is not the inverter producing the power). Or (maybe this is crazy) can you connect AC-1 out and AC-2 out to the same load? This way one would expect it to trip if too much is plugged in while on battery, but it shouldn't trip when it switches back to mains. Please help
