ian1977 avatar image
ian1977 asked
Ip22 3 output charger --> 2 outputs on the same battery
I know this seems odd and unnecessary, but is is ok to connect 2 charger outputs on the same battery bank?
I have a portable setup with 2 independent 280ah batteries that will sometimes be connected in parallel for additionnal capacity. I want to be able to charge them independently when they are at different SOC and use a disconnect switch to join them together after. This would also connect the 2 charger outputs together when doing so.
Any problems with sharing 2 outputs on the same battery? I think it will only balance the amps between these 2 outputs. Anyone tried this setup?
Thanks!
bluesmart ip22
