1) According to the documenation https://www.victronenergy.com/live/ess:ess_mode_2_and_3#running_software_on_the_ccgx_and_using_dbus_paths is should be possible to disabled the charger by setting com.victronenergy.settings /Settings/CGwacs/MaxChargePercentage to 0, but this does not have an effect and the charger is still charging the battery.
The corresponding setting for the inverter com.victronenergy.settings /Settings/CGwacs/MaxDischargePercentage works however.
2) What is the setting Settings/CGwacs/MaxChargePower used for? This has no effect.
