edurne avatar image
edurne asked
Consumption from the network and not from the batteries at night
I have an Easysolar 24/3000/70-50, the inverter and the CCGX were updated to add ESS, so that it would be powered from the grid when the batteries run out, but at night it is powered from the grid and not from the batteries. Will there be a configuration error? Are the batteries failing? I attach photos at different times.
Configuración.pdf
12-enero-1828hrs.jpg 17-enero-0920hrs.jpeg 17-ener-1430hrs.jpeg 16-enero-2210hrs.jpeg 16-enero-2040hrs.jpeg 17-enero-2030hrs.jpeg ess.jpg
ESSbattery
configuracion.pdf (465.6 KiB)
