bipedalprimate avatar image
bipedalprimate asked
Multiplus II 48/3000/35 - Decisive Voltage Classification (DVC)
As the Multiplus II 48/3000/35-32 is certified to AS/NZS 4777.2 and whilst trying to comply with AS/NZS 5139:2019, I found this:
"All inverter and PCE ports shall be classified and marked according to their DVC classification. Refer to AS/NZS 4777.2:2015 Clause 9.3.3(h) and IEC 62109-1."
AS/NZS 4777.2:2015 Clause 9.3.3 states:
"9.3.3 Ports
In addition to the requirements of Clause 9.3.2, the documentation supplied with the inverter shall state the following for each port, as a minimum:
(a) Means of connection.
(b) For pluggable equipment type B, the type of matching connectors to be used.
(c) External controls and protection requirements.
(d) Explanation of terminals or pins used for connection including polarity and voltage.
(e) Tightening torque to be applied to terminals.
(f) Instructions for protective earthing.
(g) Instructions for connection of loads and installation of RCD protection to stand-alone ports.
(h) The decisive voltage class (DVC)"
Could not find DVC on the device or in the manual so checked the certification document here:
https://www.victronenergy.com/upload/documents/Certificate-ESS-EN-IEC-62109-1-62109-2-AS-62477.1-AS-NZS-4777.2-MultiPlus-II-(GX)-3k-&-5k.pdf
Was not listed in there either.
Does anyone know the Decisive Voltage Classification (DVC) of Multiplus II 48/3000/35-32?
Where can I find it documented or where is it on the device?
Multiplus-II
