Due to electricity shortage in Ukraine, we have a lot of sites where mains voltage is 160-170V.
VE Configurator allows minimum 180V.
We need as air to low it to 160V.
Minimum voltage when charge are working also from 187V to 165V.
Unfortunately you can not configure the multiplus to operate at such low input voltages.
Yes, we realize that with a low input voltage, we will not be able to use the maximum charging current. This charging current limitation can be embedded in the MultiPlus firmware - when low input (below 180V) is choosed then charging current limitation will be applied. For example:
170V - 70%
160V - 65%
150V - only 50%
It is also about the voltage produced at the output (LV side) of the transformer not being high enough to charge the battery.
The only charger that will work on such low ac voltages, is the Centaur charger.
71 People are following this question.
