lag323 avatar image
lag323 asked
MPPT 100/30 Zero Solar watts, 0.01 Solar Volts 0.0 Amps
Current set up: 22FT 2018 Airstream
100/30 w built in Bluetooth connected (+) to hot bus bar with 10 amp inline fuse and (-) to neutral bus
1 - 115 watt Zamp Solar
1 Interstate SRM 24 12v wet battery
This is the image from the app.
Controller shows blinking "Bulk" indicator light
When I plug in the panels, I see an increase in the Battery Voltage (tells me the panels are providing some energy to the controller)
When I engage the battery switch, I see a minor reduction in Battery Voltage
As I turn lights, radio fans etc on/off there is fluctuation in the battery Voltage
What I have not seen in any change in is Solar Watt, Voltage or Current.
Where have I gone wrong or is this simply how the system operates?
MPPT Controllers
4 comments
boekel avatar image boekel ♦ commented ·
Sounds like a wiring problem, do you have pictures of the wiring?
anni-ka avatar image anni-ka commented ·
Hey,
Could you Tell me how you solved your problem? Because I have the same. Right after I plugged in my PV, the mppt tells me that I have 0.01v and no watts. The Batterie is all good.
carlrjohnson avatar image carlrjohnson anni-ka commented ·
He said that he had a loose fuse. This seems like a wiring problem. Be it a loose connection, or reversed leads on the terminals.
Matthias Lange - DE avatar image Matthias Lange - DE ♦ anni-ka commented ·
0V PV could also be a reverse polarity.
Please look trough the troubleshooting in the manual.
https://www.victronenergy.com/media/pg/Manual_SmartSolar_MPPT_100-30__100-50/en/troubleshooting-and-support.html
lag323 avatar image
lag323 answered ·
Problem solved. In line fuse on Zamp panel was loose. All systems working and readings are within normal limits.
