Sten avatar image
Sten asked
Feature request multiplus Charge current control assistent
Hi
On the charge current control assistent, i would like to have the option to invert input.
As it is, i have make a connection on the temp. input to disable charging, but i would like to have an option to break a connection on temp. input to disable charging.
The reason I think this is a relavant option, is if there for some reason is a break in the signal cable it is better the charger stop charging on lifepo4 batteries for example.
boekel avatar image
boekel answered ·
You could use a pull-down resistor, but I think you should use the bms-assistant to stop charging, that one has the default setting so stop charging with an open connection.
Sten avatar image Sten commented ·
Thanks I would try that and se if it can do the trick. :-)
