Alistair Warburton avatar image
Alistair Warburton asked
Cerbo GX Large OS - Node red - HTTPS error
Hi folks,
I have node red running on a Cerbo, which is working just fine in all respects but 1.
When accessing the unit I get an HTTPS error, presumably because of a certificate issue, and have to select advanced>go to site (Unsafe), or simmilar depending on the browser.
I probably just need to download/generate/install a certificate but cant see where to do that!
Since its only ever going to be local I guess HTTP would be a potential option but that seems like a defeetest fix and I dont know it it is possible anyway.
If anyone has any insight I would apriciate a leg up as it were,
Cheers,
Al
cerbo gxNode-RED
@Alistair Warburton
HTTP has been replaced by HTTPS. So this is not an option. Since you are accessing Node-Red locally, ignoring the "security warning" is not a problem. When you connect to Node-RED remotely from VRM, it is a secure proxy connection.
Alistair Warburton avatar image Alistair Warburton commented ·
Thanks, I didn't 'know' HTTP wasn't an option but thought that was probably the case.
I am not worried about security per se, the problem is my wife complaining that the control page will not load. Given that a certificate is now mandatory I would like to know how to add one though.
dl9msr avatar image dl9msr Alistair Warburton commented ·
I would also like to add an SSL certificate and rootCA. The certificate warning keeps repeating on an iPad. my wife has problems with it. this isn’t WAF
