bipedalprimate avatar image
bipedalprimate asked
Multiplus II 48/3000/35-32 Auxiliary Output Current
Datasheet for the MPII 48/3000/35-32 indicates that the Auxiliary Output has 32A limit.
The manual (p26 MultiPlus-II___Quattro-II_120V-230V-en.pdf Rev 05 09/2022) indicates the same device has Auxiliary Output limit of 50A.
Which is correct?
I suspect the answer is the Datasheet because the manual states the MPII 48/5000/70-50 has auxiliary output limit of 32A.
Clarification please.
Multiplus-II
Referred to Victron. Hope you get a reply soon
Thanks for the report - I'll find out the truth, report back and make sure the manuals get updated
All terms (Auxiliary output / AC output 2 / output AC-2 ) refer to the same thing.
AC output 2 on MultiPlus-II 12V/24V/48V 3kVA 120V can only handle 32A.
AC output 2 on MultiPlus-II 12V/24V 3kVA 2x120V can handle 50A (each line).
Initially, they had the same 32A rating, but soon after release, the unit was changed 50A due to customer requests.
I will make sure the documentation consistently reflects this.
bipedalprimate avatar image bipedalprimate commented ·
Thanks Guy.
But there is a but.
Although the pdf manual file name includes 120V-230V, the title page states Multiplus II 230V and the specs I was referring to relate to the 230V models. There are no 120V models listed in that manual.
The Datasheet referred to can be found at MultiPlus-II 3kVA - 15kVA 230V
Does your answer referring to the 120V models also apply to the 230V models?
