Looking for a stable powered USB Hub to extend the range of Vedirect cables if anyone can advise make and model.
Hi
I used a startech industrial 7 port usb hub.
Model. St7200usbm.
Running 5x mppts of it with no issues.
Regards Tim
How many watts does your hub use. I need a hub that uses very little power.
Also, how are you powering it? Over USB or from AC?
9 People are following this question.
