dshaw88 avatar image
dshaw88 asked
IP22 30A Charger connections
I have a 2000w inverter, wondering if it's ok to use whilst I charge my battery bank with the IP22. Also, I have the positive lead from charger connected to a bus bar (same for negative, which also has a wire routed to chassis). Is this ok ? P.s the positive bus bar has connections for charger, inverter, and 12v fusebox for the various appliances.
charger
Chargers.
