Inverter is working correctly, but after ca 1500w load it flash FLOAT led light one time. Then turns off AC out and restart system, then boot itself up and work again few sec. and restarts again...
Regards M
Regards M
They may be tripping or the voltage is dipping. Either way if the invert has a sudden shut down during inverting the battery connections or capability is where you should start
62 People are following this question.
